starcraft69's avatar
starcraft69
Direct TV HD set up
I have and use a direct tv 18" round and tripod now for 8 years and can get it set up in minutes. I would like to start using a HD dish and tripod. I am looking for help from anyone that uses A HD dish and tripod. How hard is it and what if any apps do you use or meters? I am not interested in Dish or any other set up or domes Ect. Just some help from users that use HD dish and tripod. Thanks in advance
  • The receiver tells you all you need but we have found Dishpointer Pro works well so you don't get any trees etc. in the way. After that, from years ago we have Satfinder.
    The Genie receiver has sound bars that tell you your sat strength by sound. We turn the volume on the tv up full, open a window and I can hear when I am locked in by the sound. We just discovered this and have now used it 3-4 times, works great.
  • Before I switched to dish a couple of months ago, I went down your path.
    I have the 18" SD dish and can get it setup in less than 10 minutes.
    I moved to the HD (with the power injector) as well, and as with the 18" round it took a while to get it working, the first time - adn the second time.
    The hardest part is knowing what your skew needs to be. Also unlike the SD setup - which is you get the signal as high as you can and you're done - you have to get the signal as high as you can, then set the skew and it can (and did for me) throw off my signal strength.
    What I found was it's a learning curve but if you're patient and you don't rush it, it's about a 20 minute time frame for me (the 3td and last time I did it).
    FWIW, when I moved to dish, what I was pleasantly surprised was the technology they have integrated into their receivers - which Directv seems to have not kept up with.
    One more thing. You don't have to move to dish to take it with you. you can purchase your own receiver (which you can't do with Directv) and connect it to whatever satellite dish you want (one that's designed for dish) and use it as you need it - leaving your DTV at home and using dish on the road.
    I know. a pain, but you pays you go - and the satetllite dish is about the same as an 18" dish for directv. There are always options!
    Hell.. if you're in a place with internet, you can stream what you have at home on your phone. No dish required on the road! :)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jun 18, 2025
