Gdetrailer
Nov 01, 2015Explorer III
Bill.Satellite wrote:Newer Direct receivers demand RG6 coax
While an RG6 cable is good, it's not required by any current satellite TV receiver. If you have a very long run the loss between antenna and receiver can be reduced by the better quality cabling but since we are generally not talking about really long runs the RG-59 inside a coach will do just fine.
Bill,
I would have to disagree with your thoughts on RG59 as being "acceptable" for sat receivers.
While it is possible to use a short piece (10ft or so) as a test rig, it is not ideal at all for normal use.
Typical RG59 found in most stores like Walmart, Home Depot, Lowes are only 80% shield, not 100% foil shield..
RG6 unlike RG59 is easy to find in 100% shield pretty much anywhere.
RG59 has a much higher loss at the IF frequencies, makes for much less signal getting to the receiver.. The BULK of the tuning work IS done in the receiver (important, please hold this thought)..
The LNBs do a "block" down conversion of the frequencies beamed down from the satellites, the block conversion means ALL of the sat channels are down converted to this IF (Intermediate Frequencies).
The tuner in the receiver works BEST if it gets as strong as possible IF strength.. As the IF gets weaker (long cable run or cheap cable) the tuner in the sat is not able to cleanly tune the channels.. The result is drop outs, blockies, freezing pix..
There are actually several "grades" of RG6, unswept and swept..
Sat grade RG6 is frequency swept to verify the acceptable loss in the sat IF frequencies is not too great and the coax must be able to pass this testing to be marked as such.
Many years ago, I worked for a "C" band (big dish) installer, learned all about using better coax.. If you want a trouble free install, it PAYS to do it right the first time..
RG59 is not a very good coax to use between the dish and receiver..
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
