- TrackrigExplorer II
- BobKrogstieExplorerUse the "Advanced Post Form", click the blue globe with a link on it, and follow the instructions thusly: This Is The Hot Link
- Johno02ExplorerDepending on your mounting, it will probably be as good or better than a batwing. In either case, about 70 miles or so is generally max with UHF. With my late-model batwing, and the Winegard booster inside, I have no trouble with 60+ miles direct over flatland. Much past that, the signal just ain't there at all. I have an amplified flat window antenna at our S&B, about 50 miles is good.
- Dutch_12078Explorer IIThat antenna is for receiving stations broadcasting on UHF channels only. It will not receive the several hundred stations broadcasting on VHF channels unless they're next door to you.
- rk911Explorer
Horizon170 wrote:
I wonder how this compares to the Batwing?
https://www.antennasdirect.com/store/clearstream-4-ultra-long-range-outdoor-dtv-antenna.html
EDIT---How do I make this a HOT LINK?
well, the mfg's website starts by referring to an "HDTV" antenna. seeing as there is no such thing calls into question everything else the mfg claims. - Bill_SatelliteExplorer IIThat's a good antenna as are nearly all the antennas of that basic design. However, it is not necessarily any better than a good Batwing with the Wingman attachment (or a Sensar IV). If you have an easy way to attach the antenna and put it up and down then do not hesitate in giving it a try but you can likely do as well by ensuring your Batwing it up-to-date and getting the proper voltage and signal. If you are WAY out there (60+ miles) from a tower there is a good chance that the antenna you show on a very tall pole will do better but so would a Batwing mounted on a very tall pole.
- IAMICHABODExplorer II
Just follow the instructions inThis Clicky EZ to do - FizzExplorerI tried one of these and the Batwing was better.
- Ed_GeeExplorer II
I wonder how many people this fact flys right over their heads? - SCVJeffExplorer
Ed_Gee wrote:
And if this latest channel auction ever gets some traction there will again be a completely populated VHF one day.Dutch_12078 wrote:
Back to the antenna.. for UHF, a 4 Bay Bowtie is hard to beat for its size. The published gain on that loop, if true is pretty impressive
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
