Bill_T's avatar
Bill_T
Directv card activation ??
Be gentle guys, a real newbie here.
I have a h21-200 receiver that has been disconnected for months. Will the card be deactivated, how will I know if it is activated or not?
Second question. I have an app that helps align the antenna. But I have to select the satellite from a pretty long list. How can I tell which satellite is the correct one for my system?
Thanks for any help.
  • OK guys got it. Thanks for your help. Probably will be back with more questions. Sure was simple in the 'old days" when all you had to do was turn the antenna pole and have someone tell you when you were locked in.
  • With DirecTV after 30 days of no activity the card is locked. Call them with the receiver number and they will activate the card. I have also re-activated it by "refreshing" it online. Satellite 101 is correct as donn0128 said.
  • The cell phone apps show you where you have a clear view of the southern sky. The sat you need to find is 101 for Directv. From there you will need to go to receiver setup and use the signal display to fine tune the antenna. As an alternative a n inexpensive meter like one of the used Birdogs will allow you to fine tune the signal without having to connect to the receiver until your done outside.
  • RoyB's avatar
    RoyB
    Explorer II
    My SAT RECEIVER would lose it card setting all the time when I disconnected to use in my camper. Just call the DIRECTV 800 number and have your current DIRECTV account number handy.
    I always had my account number taped to the side of my SAT RCVR haha...
    You can also login to DIRECTV and reset it there using your account number...
    Have no idea about the fancy CELL PHONE APPs
    I still use one of these in-line tone boxes
    Roy Ken
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
