CallThisCamping
May 03, 2015Explorer
DirecTV DVR with King Dome - How to use 2 tuners
Because we moved and DirecTV set me up with a genie at home, I found myself with an extra DVR. I already have an owned non-DVR receiver in the MH, so I thought I'd put the new/old DVR on the front TV and move the non-DVR to the bedroom TV since there was a satellite outlet there.
Both outlets are home runs to the King Dome on the roof.
So, here are my 2 questions.
1) The DVR has 2 F connectors for the 2 tuners built into the box, but there's only one wire from the King Dome. I know the receiver supplies sense voltage to the antenna. Is there a device that I can use to split the King Dome wire to use both tuners and still supply the 18V to the dome? Then I could watch something and record something else. (or watch a recording and record 2 different programs. I cannot do that now with only 1 tuner connected.
2) What is needed to be able to watch a recorded program on the bedroom TV like we do at home? The only wires between the 2 locations are component cables from the switcher, and the co-ax that runs separately from each receiver to the dome. There is, of course, no internet between the 2. Thought about running a x-over cat-5 between them, but it's a lot of work as the bedroom TV is in a slide, and I don't know if it would work. Do-able, but hard. I have not yet run a loose wire just for testing purposes.
