buc1980's avatar
buc1980
Directv dvr
I GOT A PROBLEM WHEN I TAKE THE DVR AND ANOTHER RECEIVER WITH ME CAMPING I CAN'T WATCH A FILM ON THE RECEIVER WITHOUT FRIZING THE SCREEN.AT HOME EVERYTHING IS OK.THAT HAPPEN ONLY WHEN I TRY TO WATCH A RECORD PROGRAM FROM THE DVR ON THE OTHER RECEIVER(H25).The system I take it with me camping it work OK at home.That the only problem I can't watch a record program on the other receiver .I can watch the program on the DVR.
  • Your dvr needs to be upgraded . I had the same problem last year and Directv has solved the problem. You should use it at home on your system and it should do an automatic upgrade.
  • OK, first, turn off your CAPS button.
    You mention taking the DVR and then you say something about "frizing" the screen at home. Could you tell us more about your setup? What kind of receiver(s) are you using? What kind of antenna are you using? Are you wanting service in your RV and your home at the same time? You say "THAT HAPPEN ONLY WHEN I TRY TO WATCH A RECORD PROGRAM FROM THE DVR ON THE OTHER RECEIVER" and I have no idea what you mean by this.
    I know you know what you mean but you need to slow down and give us as much detail about what you are doing, what you want to be doing and what problems are preventing you from doing this.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
