GTO66 wrote:
Yes that's correct on the home antenna. Just rechecked and the satellite is set to SL3 LNB with switch type SWN LNB 8CH. Here the kicker I'm unable to change any of the satellite or switch settings when on that page the high lighted goes straight to continue. It won't allow me to make any changes or even restore settings.
Those are the same settings I see in my H25. When you go to the signal strength screen are you able to select 101, 99 and 103 and if so, are you seeing good numbers there (80+)?
