GTO66 wrote:
I have 3 receivers 2 H25 and one D12. The PI is by the main TV and is working. I have done a receiver restart,and reset defaults. I haven't reset everything as I was not sure if that would cause problems with the two receivers which are working fine. For some reason that H25 is not seeing the HD sats.after using it in the rv with the swm 8 kit and the carryout.
The receivers do not interact so pushing the reset everything button will only reset everything on that receiver. That would be DTV's first thing in trouble shooting the system. If the other H25 is working properly, swap this H25 with that H25. If it still only gets 101 then the reset everything and a new satellite setup should get it going again.
