Bill_Satellite
Dec 04, 2013Explorer II
If you have a Trav'ler, that antenna has a 2 piece base so you won't need to cut anything off. Just disconnect the cables, unscrew the 9 exposed screws and the entire unit will lift off leaving the base ring behind. Buy a new mounting ring and install on the new coach! Life is good.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
