ezgoin's avatar
ezgoin
DirecTv question between house and MH
I have DirecTv in the stick house, using a Genie HDR model HR44 with 2 Genie clients in two other rooms. I'm going to have a Trav'ler dish put on the MH, so my question is can I move the Genie HR44 and one of the Genie clients for the 2nd TV in the MH? Assuming, of course, that everything is wired up correctly. Will any reprogramming be required when moving the equipment?
Thanks for your input!
  • I just disconnect the DVR and put it on the bed with my two monitors and TV. Throw a blanket over the whole mess and tuck it in. So far so good.
  • A DVR will work fine. Along with friends I also have a DVR in the coach since we bought it new in Feb 08. I know of no failures. Modern hard drives are drop (G) rated and seldom fail from shock unless its from an exceptional shock, like dropping it from a high place. We use the DVR during rest stops quite often when the antenna isn't needed.
  • I will strongly recommend that you do not have a DVR type receiver in the MH/Trailer. The Hard Drive is not made to withstand the shocks that they will get on the road. If you definitely need to do it, then please buy a thick polyurethane foam (3/4" to 1") and put under them. Please also make sure they do not move laterally. My suggestion is to get a simple HD receiver and leave it on the MH/Trailer. You will have to pay an additional receiver fee. Just add a "kitchen" receiver to your account.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 30, 2025
