Bill_Satellite
Aug 22, 2019Explorer II
If there is only 1 coax (really small coax) in the arm between the base and and the coax then you should have been sent 2 additional thin coax cables. You do need 3 coax from the LNB to the top of the base (1 for each satellite) and then 3 connections from the base of the antenna to the Dish splitter.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
