srosa
Aug 25, 2019Explorer
TechWriter wrote:chuckbear wrote:
TechWriter, Still not showing me the coax I ask about. They are coax FROM the LNB and not the coax into the RV. Chuck
See IRV2 thread.
The PDF instructions from an earlier post seem to say that the 3 coax cables from the LNB can be attached in any order:
“After the bracket has been installed, connect and tighten the coaxial cables. These can be re-connected in any order, but port D should be left open. Install the provided F-cap on port D. The F-cap will not be used if converting from a SWM TRAV’LER antenna.”
Hope this helps.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
