road_glide's avatar
road_glide
dish network two receivers - rubiks cube
If this is too long, click me and go to another post...LOL
Dish network for 12 years, 301 receiver in the S&B, took it with us in the MH and used it after set up no problems for last 3 years.
Last Dec they replaced it with 311k, did not try it in the RV.
Fast forward...yesterday I picked up a 322 dual receiver thinking I could put it in the S&B and use another tv for another room.
After 3 tries on the Dish Network chat feature and two calls the 322 in the house would only pickup 106,126 & 286. showed strong signal on 119 and 110 but status ck showed 110 red. I put the 311k (single receiver) in the RV no channels (015 channel signal lost) put the 311k back in the S&B - every channel great.
Put the 322 in the RV, getting both satelites 110-119 but only 341,342,343, hallmark and a few others. No locals.
Crazy, ....311k works fine in S&B, not rv. 322 dual only works on 2-3 channels in S&B and in the rv now gets different channels, 8-12 different ones, again not all.
DW said just leave the 322 in the RV and leave the 311k in the house and we get all of our programming no problem at least in the house and we will get some in the RV, I hope.
SO...as of now, I have the 311k back in the house working fine and the 322 in the RV getting some channels. I have a Kingdumb 9702, that worked ok with the other receiver (301) prior, just set it up, a little tedious but always worked.
If any body has any thoughts or input, you're welcome to chime in.
It's a crazy situation as I would love to have the 311k (single) in the RV and 332 (dual) in S&B but it's not working out.
Maybe the 322 I got from an individual had issues with input/reception, their past acct was clear so I added the receiver to mine.
It's just weird there is no distinct pattern...
If I get advice to have a tech come out, I will wait and see Sarge in Sacramento. The last Dish tech did not know how to menu 6-1-5 to move the modulator to channel 3-4. However, I know they just want to do what's quickest and get out...I have no problem with that.
  • Gordon three...thanks for chiming in..
    I have Kingdome 9702 saved on my computer under RV manuals, I will look for what it supports or google more info. I also have the paper copy in the MH. Same but I did notice reading the paper manual it said originally set up for directv. Online manual does not reference directv.
    That being said for 3 years rving, no problem with the old dish network single receiver 301.
    I've done a lot of searching and reading the last week when I ran across the 322 dual receiver. I bought it Saturday and installed it first in the house.
    I did see quite a few blogs where the LNB's had to be changed out....probably headed in that direction.
    I believe our house has a 500 dish 12 years old....
    You are the first that had a more definitive experience, quite of few of the blogs were vague or repetitive.
    Bottom line, might need a new LNB for the house dish to support a 322 dual receiver and the kingdome 9702 may not support fully the new 311k that Dish has brought out for their subscribers.
    You and I realize that every time new electronics evolve there is cause and effect....meaning do something new and you will be forced to upgrade all of your equipment.
    Thanks again
  • Does your dome support a dual tuner receiver, is it mentioned specifically in the manual?
    I don't have your hardware, but I think the dish and the receiver have to be mated and / or matched - it's not like terrestrial antenna where you can just plug things in.
    My experience with Dish, I started with a single tuner and upgraded to a 922k dual tuner, and Dish had to come out and install a larger dish and LNB with 3 horns. When I went from the dual tuner 922 to the triple tuner Hopper, they kept the same dish but installed an even larger LNB, this one had 4 horns on it.
    In summary, your dome might need a new LNB, or might just not be compatible with your newest tuner.
  • I have the Kingdome 9702 manual and I will go through it and see. You mean the smart card?
    When I turn power to satelite in MH, it acquires signal (after I manually locate) and then downloads program guide. When that is done then I still only get a few channels on the program guide. Most say partial channel reception or no signal..
    thank you newman
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
