dfddeere's avatar
dfddeere
Dish Playmate hookup
I have a 2021 Forest River Surveyor Luxury. I have tried to hookup a Dish Playmate to the outside cable connection but it doesn't play on the TV's inside. Is there a filter on the cable line that keeps the signal from getting to the receiver?
  • I bought a Wally with a Playmaker dish, if only I would have known a Playmate was available. :W
    The Dish Playmate is a smart satellite dish that has to be hooked directly to a Wally receiver via coax cable. The Wally is then hooked to the TV via an HDMI cable. Hooking the Playmate directly to the TV get you nothing.
  • I could never get my portable dish to work when hooked to the cable connection. I had a technician put in a dedicated connection that went directly to the receiver and it worked perfectly.
  • Odds are your RV has splitters in the cable coax. Satellite antennas will not work with splitters in the coax. As stated above they must have a direct coax connection between the antenna and the receiver.
  • Some Sat dishes are powered by the receiver,
    They need a direct cable connection to the receiver, no switch boxes can be In the line
  • I am not an expert on this, but my trailer has two hookups, one for the cable, and another for the satellite. I don't know what the difference is, but it works.
    Mike
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
