Gonzo42's avatar
Gonzo42
Dish Receiver burn-up
Recently I bought a Dish DVR at CW. It took 2 calls to get the software upgrade plus ensure that I paid only the $40.00 one-time charge vs $10.00/mo forever.
Then the receiver died. Dish is sending a replacement. I wonder if the little hard drive, which gets its power only from the USB port, made it all run too hot.
  • Mine has been running on the USB without external power for about a year with no problems.
    I think your problem was just luck of the draw.
  • It may be the hard drive but it may also be heat. Depending upon where you have the receiver placed, if it does not get good air circulation it will die a pretty quick death from over heating.
  • I use a hard drive from a laptop. I had to get a Y cable, one usb goes in the 211k and the other usb is plugged into a usb phone charger. It would not work plugged only in the 211k.
  • BB_TX wrote:
    When I bought my Dish vip211k several years ago, Dish recommended using an external hard drive powered by 120 vac. And not to use one powered only by the USB port. Even so, the vip211k does get pretty warm when left on for extended periods.
    yep, mine wouldn't work with the USB powered one. had to go to external power source.
    bumpy
  • When I bought my Dish vip211k several years ago, Dish recommended using an external hard drive powered by 120 vac. And not to use one powered only by the USB port. Even so, the vip211k does get pretty warm when left on for extended periods.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
