jrclark's avatar
jrclark
DishTV 211z receiver.
I am thinking of changing from Direct TV to Dish TV.
I understand that a hard drive can be added to the 211z receiver to allow it to function as a DVR. I know that I would have to have Dish TV activate the receiver to function as a DVR.
My question is: What are the steps for recording a program? And, when you want to watch a recorded program, is there a list displayed to pick from?
  • Bumpyroad wrote:
    by adding a hard drive is this put into the 211 it self or just stand alone? if stand alone, can't see how setting it is that easy. if installed into the 211 can you just order one with it already installed.
    bumpy
    Stand alone. It need to have its own 110v power source. The hard drive plugs in with usb.
    Pat
  • by adding a hard drive is this put into the 211 it self or just stand alone? if stand alone, can't see how setting it is that easy. if installed into the 211 can you just order one with it already installed.
    bumpy
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Dish software is based on REPLAY TV which I know well.
    To record: Go to program guide and press the red-dot button
    Or press Select and choose "Record"
    To record a daily or weekly show....
    Press Red Dot twice or select and choose record
    When you select and choose you can choose to
    Record ONLY this show
    Record ONLY First run shows
    Record First Run and Repeats.
    IT has been a bit since I did a Dish unit (About 18 months) but on my Replays I can also set up theme channels.. For example I tell it to "Record all shows, any channel, any time with a title containing "CSI"
    CSI: (original series)
    CSI NY
    CSI Miama
    All get recorded. Caution when using this on dish.. Several networks do show-a-thons all the time.. For example 10 hours of NCIS a day or BONES or ,,well, CSI.
  • To record you just select the program in the program guide and press the record button on the remote.
    To watch recorded programs press the Dish On Demand button on the remote and select from the recorded programs list.
    Since it is a single receiver box you can't watch one program and simultaneously record another for the same time slot.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
