Klueck's avatar
Klueck
Duo Therm AC and heat pump not working
We have a Dometic DuoTherm Ac with heat pump that's not heating or cooling.
For over a year,there was a crackling noise when the compressor quit running, but it cooled and heated fine.
Now, we've notice neither the heat pump or the cooling is working. Our front Ac unit runs fine.
The fan works fine, but when I have the AC on automatic, the fan just keeps running, but it's not cooling.
Any ideas what this may be??
  • First, go to the front A/C, and listen to it when it starts up. You should hear the fan blower start(air starts moving), and then about 2-3 seconds later, you hear a low rumble with a vibration that you can feel with your hand. This is the normal startup either for A/C or heat pump.
    Now, you should do the same on the unit that's not working. You probably won't hear the low rumble/vibration. That's the compressor not starting up.
    You've probably got a bad start capacitor, or bad compressor.
    Now you hope that it's only a bad capacitor.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
