4x4FF's avatar
4x4FF
Ethernet (RJ45) Jack on 5th wheel sidewall
Hi all,
I use a ubiquiti nanostation as a wifi repeater in my 5th wheel. I have the nanostation mounted on a piece of 1" PVC conduit so I can remove it for travel. Long story short, I want to put an ethernet jack as a passthrough on the side of the 5th wheel. The interior cat5 cable that runs to my router will be permanetly connected to the inside of the passthrough. The outside connector is where I will connect the cat5 that runs to the ubiquiti when in use then sealed when not in use. I am looking at getting the following and was wondering if anyone had a better solution for an weathertight ethernet passthrough that can be sealed.
Passthrough
Cap
Connector
The only concern I have with the above parts is the thickness of my sidewalls.
Steve
  • RoyB's avatar
    RoyB
    Explorer II
    Another method I have used with great success is to mount a regular electrical PVC junction box on the outside wall. Then drill out a 1-inch or 2-inch in the center of this junction box. On the inside wall adjacent to this outside PBV box mount a similar PVC junction box.
    I would run a Flex or solid tube between the two mounted boxes. You can run many cables thru this idea from the inside to the outside all weather tight. These boxes come with any number of ports to use...
    You can use all different sort of these PVC junction boxes where I was routing DC cables and such. I would mount PVC 3/4-inch tubing and route all this to just about anywhere. All out of site or at least neatly dressed in around the wall or what ever...
    On the outside you can add connectors etc to the weather tight lid...
    The also have weather tight lift covers as well...
    Like said all of my BATTERY cables routing to my to/fm my tongue mounted battery banks use this idea to route all my 12VDC cables through PVC flex lines all over the trailer.
    On my off-road POPUP CAMPER I pulled all of my wiring that went through the trailer floors under the various cabinets and did the same thing here. Now all of my DC Cables are well protected going thru the PVC flex tubing and junction boxes mounted under the trailer floor.
    Something like this trailer floor plan shown in blue here...
    Go walk around places like LOWES or RADIO SHACK and see whats available with installing your cables.
    Roy Ken
  • RoyB's avatar
    RoyB
    Explorer II
    I have added several different antenna connectors to my trailer exterior wall and used this type of weather tight lids available from LOWES. I just installed them close to were the original CABLE TV connectors were installed.
    Lowes also had the different connectors like the F connector etc. I found the Ham Radio type connectors I needed and installed them instead. I noticed they also had some type CAT 5 connectors you could use as well.
    Roy Ken
  • aslakson wrote:
    Looks like a good plan, although sorta spendy for my blood. I'd drill a small hole thru the sidewall of your rig and measure the wall thickness - not necessarily through the insulation and inner wall, but just the outer wall. Inside, you can make that hole as big as you need, and if it's inside a cabinet or behind some furniture, it won't show anyway.
    al
    Thanks for the reply. This so far is the best solution I have found. Really it is only about $26 all together so not too bad. I guess I'll use a 2" hole saw from the inside and then just drill an appropriate size hole through the outer skin. That is the only part that bothers me. Obviously this wont fit all the way through a 2" thick outer wall.
    Just checking to see if anybody had any better ideas.
    Steve
  • Looks like a good plan, although sorta spendy for my blood. I'd drill a small hole thru the sidewall of your rig and measure the wall thickness - not necessarily through the insulation and inner wall, but just the outer wall. Inside, you can make that hole as big as you need, and if it's inside a cabinet or behind some furniture, it won't show anyway.
    al
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
