pbitschura's avatar
pbitschura
exterior solar plug
Our 2020 travel trailer has an exterior jack labelled "solar". What do I need upstream of that plug to charge my house battery? I assume these jacks are standard so some "plug-and-play" connectors also exist. Thanks in advance.
  • pianotuna wrote:
    That depends on what is after the jack.
    If there is a charge controller after the jack, then Bob's your Uncle. Add solar panels.
    If not then panels connected to a charge controller, and connect the controller output to the jack.
    there is no charge controller in the inverter/converter onboard then?
  • That depends on what is after the jack.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
