az99's avatar
az99
Garmin RV 760LMT Tips
I know there have been at least a million threads recommending this unit. I decided to try one. Can anyone share some tricks and tips to make life easier for users of this unit. Their manual is rather generic. Tips like building custom routes and adding POI's etc.
Thanx
  • Posted By wrote:
    I am confused. BC shows I can't do anything without the GPS connected.What does Mapsource do?
    Wouldn't it be easier to just use MS S&T and export the GPX file?
    When you download Basecamp it has a basic map but to create routes you need the maps loaded on your GPS. There are two ways to do this. The first is to connect your GPS to the computer and use the maps on the GPS. The second way is to load the maps that are on your GPS to the computer. You need to download Garmin Express it is used to update you GPS and as you update your GPS with new maps you can store the map to your computer. Once the map is on the computer you can create routes without the GPS connected to the computer and when you are finished connect your GPS and transfer the routes to the GPS.
    Mapsource is no long supported by Garmin but does the same things as Basecamp.
    I don't know anything about using MS S&T.
  • The normal GPS unit should be used for informational purposes only and not for the gospel way to get there. I use mine mostly for routing thru major cities when exits could be on the left or right
  • I am confused. BC shows I can't do anything without the GPS connected.What does Mapsource do?
  • phoenix.bears wrote:
    .........................snip
    Was on the Oregon coast, Newport, and headed to Coos Bay. The 760 wanted me to go East to I 5, then South and eventualy West to Coos Bay. This was MILES & HOURS out of the way. I have done this trip many times and my Nuvi had no problem going right down the 101 so I went. At every oppertunity, even some dirt roads the 760 instructed me to turn around and go back to Newport & follow IT'S instructions. Eventually after many miles it gave me a low clearance warning. I chose to ignore it & continued on following the Nuvi. As we neared Coos Bay the 760 gave up deciding this was the way I was going to go. Called Garmin and gave them the details. I found out that I should have taken "screen shots" using the camera ikon in the upper right corner and sent them the informatiom, at the time I did not that. I asked Garmin to duplicate my trip, they could find no problem. Without the NUVI or my own knowledge I would have gone hours & miles out of my way, and to say the least would NOT BEEN HAPPY.
    This is why I say as point and shot they suck. Down load Base camp from the Garmin site; not very good as a routing tool but better then point and shoot. After installing Base Camp; down load and install Mapsource from the Garmin site both are free. Mapsource is a great routing tool. It doesn't have the over head that BC has, interfaces better with Google Earth and since they aren't doing updates doesn't crash like BC does every other time Garmin does an up date.
    Mapsource should load directly to the 760, I think the 1XXX models are like the 2XXX and 3XXX models, you'll need to import the route(s) from Mapsource to BC to upload.
    Thanx
    Download Garmin BaseCamp to make custom routes and you will really like your G P S.
    www.garmin.com/en-US/shop/downloads/basecamp
  • I have used a Garmin since 2004. Currently a Nuvi 1390 for the toad & coach as well as the 760LMT. I don't go anywhere without one or both being on.EVEN in my own neighborhood. The 760 replaced the earlier RV of the same size when it was not possible to update any longer. Both now have lifetime MAPS & TRAFFIC. Both were updated in Oct. 2015 before my current trip. Have had no problems until this trip. thinking seriously about doing something else.
    A few other little things on my way to San Diego where I was born & raised. Then it started to direct me off the freeway & at the bottom of the ramp then directly back up the on ramp??? Several times there was also a short 2 or 3 block detour then back up the ramp.These were not new changes to the road and there was no reason for it, I am & was on those roads for years and there were NO CHANGES.I have now traveled from San Diego & presently am in Natachz TN. There have been a number of strange problems along the way. Both units are updated with current maps but find a big difference in them. One can find Home Depot wthin a few miles, the other says over 200 miles. can find a city in on , not in the other. I I dont find a reason to keep the 760 may try to get rid of it and look a Rand McNally RV model. I like the 760 but now have many doubts.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
