siggyd777's avatar
siggyd777
HDMI Audio ?
Does an HDMI cable carry audio?
I connected my Toshiba Laptop to a Vizio TV and have PC screen duplicated on the TV. But when playing a Video with music / audio,
I get no sound from the TV,only from the Laptop.
Whats wrong?
Siggy
  • Thanks again, found the problem.
    Went into: Control panel, Sound , "E370VT-1" , right click, Enable!
    This turns Off my PC speakers and turns ON the TV speakers.
    If no HDMI cable is plugged in, the PC speakers work.
    What would I do without Y'all?
    Thanks,Siggy
  • Thank you all for the replys,I will check it out and let you know if I get it to work.
    Siggy
  • I just remembered something
    Have you checked the audio settings on the vizio tv
    Some tv's allow you to enable or disable different audio inputs
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I know my Chrome Cast Receiver delivers Audio via HDMI.. I normally keep audio off on the comptuers.. Which reminds me of something I need to download twit.tv/hn
  • JiminDenver wrote:
    You may have to get into the settings on the computer and enable the speakers on the screen.
    This is a common issue why HDMI audio doesn't play in videos on a computer. I would also check your PC audio settings.
    This.
    Sometimes, the computer switches automatically. Sometimes, you need to select the TV speakers when in the audio settings. And sometimes, nothing works because your computer doesn't have the drivers needed for the TV speakers to work. If this happens, it may help to download generic tv speaker drivers.
  • You may have to get into the settings on the computer and enable the speakers on the screen.
  • Try this turn off both of them
    Make sure TV is plugged into pc
    Turn on tv and select the HDMI input
    TV will show no signal
    Now
    Turn on pc and start your video
    Btw
    What program are you using, I hardly ever use Windows player
    I use VLC Or. MPC-HT
    I watch video on the TV from my pc
    As stated above it could be in your audio device settings
  • Yes, HDMI does transfer audio. It's possible your laptop is not set up to transfer audio that way though. You may need to change preferences in the audio setup. And it's also possible that, depending on the price, your laptop may not be able to send audio over the HDMI cable, only video.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 26, 2025
