Gene_Ginny
Apr 04, 2015Explorer
FWIW: The ASUS 1015PEM17U uses a 19 volt charger which is in tha ballpark with most laptops, that I know of. My HP laptop charger is 18.5 volts and a higher current rating than the 10.1 inch ASUS netbook needs. Nothing unusual about the charger.
Seems like the first steps would be to measure the charger output and measure the battery voltage to see if it is close to what it should be. The 6 cell battery should be about 10.8 volts when charged.
The comment by Charlie D about the external drive is worth noting.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Apr 25, 2026
