westend
Apr 05, 2015Explorer
This has worked for me for non-functioning laptops: Check charging brick for correct output (should be around 19VDC). Remove battery from laptop. There are a row of contacts on both the battery and the laptop. Apply Caig Deoxit D5 to both sets of pins and allow to work for 30 minutes. Wipe up excess fluid and reinsert battery a few times into the laptop. The last will insure that any oxidation or dirt is scrubbed off the contacts. Plug in the charging brick.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
