Squealers
Jun 05, 2019Explorer
Since posting, and while pulling out the big tube box that held the old TV I found the 2 wires coming from the roof into the component cabinet. One is gray coax, the other is black. Pulling out the end that was tucked behind the cabinet, it has a handwritten Sat Ant taped to it. It is the black coax coming from the roof. SO I am assuming the gray coax is the batwing. I will do the tests you suggest Bill. IN regards the the Ant power, I don't see a power option in the component cabinet for the antenna per say...I have a TrackVision switch that has a power button and a Sat Selection button. Should we assume the power button also powers the batwing antenna?...I know I can test that in the ways you mentioned...just spitballing before I have a chance to actually test it. I also have a panel that says To Satelite Receiver with an Input and Output connector. There are no switchers or boxes in the cabinet....just a rats nest of coax and the simple silver Walmart style coax splitter. Thanks for your help!!!!!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
