Snowman9000's avatar
Snowman9000
Help troubleshooting AV cables
Our new MH has the DVD player built into the dash head unit. Near the TV there are wall jacks for Red/White/Yellow AV cables. The DVD dash unit is supposed to be connected to those jacks by the TV. I have connected a cable set from the jacks to the matching AV input on the TV. When I play a DVD, it shows up on the dash screen but my TV says nothing is connected on its AV input.
Can I check volts at those wall jacks, to see if something is being sent to them when a DVD is playing?
  • Before I could post answers to the questions, I tried it again tonight. With everything the same, it worked. But with a lot of interference. The tv is one with a brick, which I had bypassed. It is plugged direct to 12v. So I changed it to the brick plugged into 110v, and it worked perfectly. I'm not sure what to think of that since the tv otherwise works great when plugged direct to 12v.
  • You probably need to select the right input on the TV menu. Try this, turn on DVD with a DVD in it. Then with the TV on, select MENU on the TV remote and find INPUT, it should be on the remote itself. now change each INPUT one at a time until the picture shows up. there will be 4 or 5 INPUTS, you just have to find the right one. Good luck
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Question: Are those jacks on the TV faceplate or are they on a wall plate near the TV?
    Reason and true story: On my main TV they are on the TV, but there are also a bunch of jacks on the back for assorted types of input including another copy of the A/V Line in (Red/White/Yellow) and also a set of output jacks.
    Well... I could not get it to work with Line in from the rear, worked fine from the front but not from the rear.. Finally I accessed the rear of the TV and this is what I found
    OUT AV-1 AV-2
    X . . 0 . . 0 Video
    0 . . X . . 0 Audio
    0 . . X . . 0 Audio
    X means there was a cable plugged in.. I think you can see how I fixed it.
    What does this mean for you? Are you sure the wall plate jacks are connected to the TV?
    Page 2
    If like me you have a "home Theater".
    IF I play a source via the FRONT jacks, the TV does it all
    But if I play via the factory REAR inputs (I got to fix that one of these days) the show goes first to the Home Theater and THEN on to the TV So I have to have it on as well.
  • Are you sure that in dash unit is not an INPUT rather than an OUTPUT?
    Just wondering based on units I have owned in the past.
    Do you know the in dash unit make and model?
  • There's really no meter to test the jacks. A TV monitor is what's needed and you have that. I would make sure you TV is set for the correct input your hooked too. It may have 2 or 3 such inputs.
    I would also make sure your head unit doesn't have a setting where you can turn on or off the second output.
    Are you sure your cables are good. It would be very unusual for all 3 to be bad at the same time but you never know.
    Are you sure the jacks by the TV are outputs? They may be inputs where you could connect a game system or something and play it thru the head unit.
  • Have you gone to the television menu to set the TV to the correct set of connections? Most TV's now have 6 or more sets of connections to be used.
  • First you might want to check if your TV has a menu where you can select different inputs.
    On mine I have a video switch box simply because its way too hard to get to the back panel every time I want to change inputs. It requires unbolting the TV from the shelf.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
