ccchuck's avatar
ccchuck
html help..
I have a bit of html code that displays a set of URLs in sequence continuously with a 30 delay between each.
(I didn't write it, I found the code ), now I want to have that to appear in a window while the main window displays the local temperature, i.e., a window within the main browser window. I hope that makes sense.
This whole thing is a weather watch.
If you're bored and would like to help it would be greatly appreciated-
  • 1492 - thank you very much!
    and camperpaul thanks for chiming in as well.
  • Think of the <div> tag as a container, which is uniquely identified by its "id=". Whatever you place between a <div id=""> and stays within that container. You can have as many <div> containers as you want, and nest them within each other.
    In this case, the Accuweather widget was placed within the <div id="box"> container that can be positioned anywhere.
  • To get a basic idea of CSS, go to w3schools.com and delete everything in the left column "Source Code:". Then copy and paste this text file using Accuweather widget as an example:
    Click the "Submit Code" button. Change the "left" and "top" element in the
  • Frames have long been deprecated, should be avoided, in current HTML specs.
    What's used to set and position a window within a webpage is CSS. One way is to define the window properties in the portion of your webpage using a
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
