- LearjetExplorer
opnspaces wrote:
The problem is with the short generator stub cord. Now you have to stand there and hold the generator in the air while in use.
not if you use the extension cord that I already have. :D - opnspacesNavigator IIThe problem is with the short generator stub cord. Now you have to stand there and hold the generator in the air while in use.
- LearjetExplorerAnswers...
The white/black wires under the cover go to sensors for an Efergy energy monitor system that shows the Watts being used...they just go to clamp on sensor and have no voltage passing through them to speak of....I could clean that up some. I use it to measure the electrical energy use...I have it wired so It also show the generator load when on emergency power. The wires go to a battery operated transmitter that sends the info to a wireless display.
Yeah one of the covers looks crooked in the picture...but it is not when closed.
Yes the male cord is a generator inlet, I used the RV 120 Volt 30 amp homemade inlet because I have plenty of those extension cords already and it goes into the 30 amp RV plug on my Champion....thought about improving that in the future.
The square box is a whole home surge protector.
The EVSE is the charging cable for my Nissan Leaf EV.
cleaner pic.
I didn't pick the paint..bought the house like that...the picture below has some reflection from the tail light of my truck on it...FYI
I originally had the sensor outside...but moved the transmitter inside for a better signal... - DownTheAvenueExplorer
zigzagrv wrote:
drsteve wrote:
Male connector on the gen cord, maybe?
^^^THIS^^^
Nope! This is very standard for larger portable generators. - zigzagrvExplorer
^^^THIS^^^ - drsteveExplorerMale connector on the gen cord, maybe?
- mich800Explorer
YC 1 wrote:
Manual transfer setup to let the RV power the home. Looks like a mechanical device to shut off all incoming breakers so power does not back feed to the utility company.
Typical backfeed setup with some interlocks to help reducing the chances of powering up the suicide cord. - YC_1NomadManual transfer setup to let the RV power the home. Looks like a mechanical device to shut off all incoming breakers so power does not back feed to the utility company.
- C_B_ExplorerYou didn't pay the power company/They shut it off.
- joebedfordNomad IIThe colour of the wall is pretty, ummmm, interesting.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
