tjatkinson's avatar
tjatkinson
In Command Travel Lockout HELP!!!!
We just bought a new RV with the In Command unit. We have unhooked the RV and leveled it, but our slide and our awning will not work, because our Iphones say we are on a travel lockout and each system says disabled without the option to enable it.
Can anyone help us?
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to posting issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM POSTING HELP AND SUPPORT
  • To perform a manual override look for the BCM "Body Control Module", it should be under the floor compartment, open it up and there should be a dial knob and momentary switch, just try them out (mine m1 is the slide and m5 the awning) hope this help until a solution has been found
  • After reading many of the article on the website now, and i genuinely as if your strategy for blogging.
    I bookmarked it to my bookmark collection list and i will be checking back soon. Pls take a look at my internet site as well and tell me if you agree with me.
  • I had the same problem on my Cougar 316RLS. Talked to the folks at InCommand and they were very helpful. Turn power off at the screen by holding the power button until the power off message comes up. Hold the power button down until you see a white flash and let go of the button. You should bypass the Travel Lockout message and go right to the login screen. You should be good to go at this point, but I found out that I needed to do a software update and that fixed the issue.
    Good luck!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    One thing you might try is to RESTART the phone.. Sometimes phones get "Hung up"and neeed ye old REBOOT.
    Sometmes a type on (Turn after recharging after battery dues)
    Sometimes type two (Not sure how to do it on an I phone my Droid long press power and choose Restart)
    Sometimes type 3 (Do you want to restart not/later)
    Not many have type 4 (Hardware reset button) or if they do special tool needed.
    Sometimes the only choice is type 5 (Steel toe boot)
