TenOC's avatar
TenOC
Nomad
Jul 13, 2018
Internet connection not working -- CAT5e
My RV is 300 feet from my S&B home. About 5 years ago I ran (in a pvc conduit) a underground gel filled CAT5e cable from the S&B to the RV. I got good service at the RV with about the same speed as at the S&B.
I have now returned from 6 weeks on the road. I no longer have internet service at the RV. I do not know if there was any type of storm damage or other thing that could have "knock out" the cable while I was on the road.
I have tested the cable and I get a "pass" with one of these tester.
CAT5 Tester
Even with a "good pass" cable I can not connect to the internet. Is there some other type of tester that I can use to find out what is wrong?
  • MarkTwain wrote:
    Contact your Internet provider and explain the situation? solution?Since AT&T did not run the 300 foot cable, they do not want to help.
    Can you get internet wirelessly?
    300 feet is too far for wireless
    Could your CAT5e have a break in the wiring? If there is a break the cable would not test good
    Try connecting a new CAT5e from RV to House above ground to test your older CAT5e cable. That is my last choice since 300 feet of CAT5 will cost almost $50.00
  • rk911 wrote:
    do you have internet st the house?
    Yes, I still have internet at the house
  • Contact your Internet provider and explain the situation? solution? Can you get internet wirelessly? Could your CAT5e have a break in the wiring? Try connecting a new CAT5e from RV to House above ground to test your older CAT5e cable.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
