JimChow's avatar
JimChow
IPhone 5C help
I have an Iphone 5C and an old (2006) HP Laptop. Is there a cable that goes from the Iphone to the laptop that I can use to watch movies on the laptop off of the Iphone? I can down load movies from Comcast, but because I didn’t use ITunes using the USB/Lightning cable the movie doesn’t show up on Itunes…..if that makes sense. I do not have a HDMI connection. I have a 15 pin (female) DB monitor connection on the laptop and a S Video connection. Any ideas?
Thanks
  • no, but when you connect your phone to the computer the PC will see it as an external hard drive and assign it a letter. you should then be able to simply drag and drop the file from your phone to the PC and watch it that way.
  • The iPhone lightning (charging cable) has a USB on the non iPhone end, but it can only be used to talk to your PC via iTunes. NO way that I know of to assist with watching movies on your older pc.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
