Dec 22, 2013Explorer
As some have said it can be done. If you are not comfortable with small circuit boards and connectors, prying a case open that is not made for you to open it, and ordering a battery that "should" fit online, then go to an Apple store and let them do it. At least if it does not work after, they will be responsible to get it working again. The tech there has done hundreds, if not more.
If you are comfortable with the process, try it. DIY will be cheaper.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
