SCVJeff
Jan 08, 2014Explorer
I don't recommend the Jack over the Batwing simply because the Batwing is a better performing antenna. IMO, physical interfearence is about the only good reason, and you gots a good one..
Bummer...
To answer the 1st question, yes. All you need to do is plug in the coax. The only difference is that the Jack lines up with the arrow on the Winegard pointer vs. Being 90 degrees off on the Batwing.
Bummer...
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
