YC_1
Jan 08, 2014Nomad
Guess I have to disagree with the batwing outperforming the Jack.
IF the batwing has the add on then yes, the gain is a bit more but is much more directional. The Jack was designed with the UHF frequencies used by most of the current television stations due to the Digital change which also included a frequency change.
I have installed several Jack antenna's and they perform extremely well.
Well worth the money and changing the head is a breeze. Needle nose pliars to remove a couple of C clips, some tape to re-secure the coax and you are done.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
