wa8yxm
Jan 08, 2014Explorer III
Yes, you just replace the head and connect the coax (MAKE SURE YOU HAVE SELECTED CABLE OR TURNED OFF POWER TO THE BOX OF MANY BUTTONS before removing the Batwing.
Then, if you have the wingman added, you can expect much poorer performance from your new antenna.
Suggestion: Before you spend money on the Jack, replace the section of coax that goes from the roof bulkhead connector to the head.. This often "Wears out" as it were.
The Batwing is 3-10 DB more powerful than the Jack depending on the frequency. OR MORE.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
