gotsmart
Jan 10, 2014Explorer
Does anyone know if there is a design difference between the JACK RV Antenna Replacement Head and the JACK HDTV Antenna + Mount w/SureLock that would preclude one using the JACK HDTV Antenna + Mount w/SureLock from replacing the JACK Power Injector Switch Plate with a Winegard SensarPro TV Signal Strength Meter?
I like the idea of setting the channel number on the meter of the station that I want to find and turning the antenna for the best signal strength of that channel.
Can the JACK HDTV Antenna + Mount w/SureLock and Winegard SensarPro TV Signal Strength Meter work together?
Should it not be done?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
