- broboxExplorerIt really depends on where you are going to travel. If you plan on going to out of the way and beautiful places such as Yellowstone, Grand Tetons, etc. the Jack will not receive jack as there are no OTA station.
- REWahooExplorer
Jerry Roberts wrote:
I've read that the Jack TV is a lot better than the Winegard. And some people are getting 80+ channes with the Jack antennea. I don't believe everything I read on the internet, so I was wondering if there is any truth about the Jack TV getting as many channels as satellite.
Absolutely no truth to what you've heard.
I recently replaced my batwing (Winegard) with a Jack and saw a slight improvement in OTA reception. The Jack is a bit less directionally sensitive and I am getting a slightly stronger signal, but I'm not getting any more stations than I was with the batwing. - Tom_M1Explorer
Bill.Winegard wrote:
Also, only the X.1 channels are HD. All others are SD.
This generally is true but there are exceptions, Minneapolis being one of them. Two stations are broadcasting two HD programs. Each of these stations are using two transmitters, each broadcasting on different RF channels. Each of these channels are then assigned the same main virtual channel through the magic of digital manipulation (PSIP). KSTP has a channel listing of 5.1, 5.2, 5.3, 5.4, 5.6, and 5.7. 5.1 and 5.2 are HD, the rest SD. To the viewer it appears like it is a single main channel. - Peg_LegExplorerDowntown LA I could probably get 100 channels, Middle of nowhere, Iowa (sorry Iowa) maybe 2.
So be happy, get both. I think the HD pic quality is better OTA. - sclarkExplorerI replaced my Winegard with Wingman with a Jack. It has been my experience that the Jack does a better job on the UHF channels. Winegard seemed to do better with the VHF. As mentioned above the network selections are far better on satellite. We tend to camp in the middle of nowhere which greatly reduces the number of over the air channels that can be received. We also carry a Direct TV Dish and tripod. Good luck.
- accsysExplorerYou cannot get ESPN or any other sports package with a Jack Antenna - nuff said.:B
- Bill_SatelliteExplorer II
Thanks. However, I've used Directv in the past and currently have Dish Network as my cable provider. I should have added that, I've read that the Jack TV is a lot better than the Winegard. And some people are getting 80+ channes with the Jack antennea. I don't believe everything I read on the internet, so I was wondering if there is any truth about the Jack TV getting as many channels as satellite.
While there might be isolated cases where someone received that number of channels you need to understand that none of these channels are going to be things like CNN, The Food Network, History Channel, etc. Those are paid cable type channels and require some kind of subscribed service to receive.
Additionally, someone showing a large number of received channels is getting channel 3.1, 3.2, 3.3, 3.4, 3.5 and 7.1, 7.2, 7.3, etc. so may not actually provide what you would consider unique channels or even normal viewing channels. Also, only the X.1 channels are HD. All others are SD. ABC might be on 7.1 and a 24 hour loop of the weather will be on 7.2 and paid advertising on 7.3 or Spanish language programming on 7.4.
You are never going to find anything comparable to satellite or cable with an OTA antenna but if all you are interested in is the major Network programming the OTA antennas do an excellent job as long as you are close enough to the TV towers to receive them. I did receive over 50 channels in the LA, CA area. I watched the NBC news at 5:00 and then went back to satellite for the rest of the time. - Jerry_RobertsExploreryes, i used to take my directv and always got my local channels; however, we never really went far from home. the furtherest we have been was niagra falls in canada which is about 6 hours or so from our house.
- camperpaulExplorerOn the UHF channels the Jack and Winegard are about equal.
The Winegard will work on the low VHF channels where the Jack works poorly if at all. Yes, there are a few stations still using low VHF channels.
The number of OTA channels you will receive is a function of your location. I am currently near Racine WI and I get all of the Chicago and Milwaukee channels using a Winegard with Wingman.
If you already have Dish Network at home, you can take it with you but if you travel too far from home, you will lose your 'local channels'. - brireneExplorerI've not camped anywhere where I got anything close to that number of ota channels. I've gotten maybe 10-15, but not much more than that. I'm not usually very close to large cities, so that may increase the number, but its not been my experience.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
