Gdetrailer
Dec 30, 2014Explorer III
LittleBill wrote:
if the only input is the composite cables. you will be sorely disappointed with the quality of the image. computers look like junk on composite
THIS!
Homeless, I explained that to you in your OTHER post..
You will only get TV "SD quality" IE STANDARD TV RESOLUTION (AKA 480i" which is far, far less resolution than a PC monitor.
Your laptop most likely is set to 1024x something (depends on wide or narrow screen) at a minimum.
TV SD quality is equivalent to about 320 x something when comparing as computer video equivalents..
Composite input IS NOT WORTH PURSUING as a substitute screen for a PC.
I tried that many years ago just so I didn't have to drag a TV and PC monitor while camping.. Bought a VGA to TV adapter.. Had to set the computer down to 600 x resolution and the TV screen was STILL nearly unreadable.
STOP. Do not pursue this method, you will be kicking yourself after wasting the money on this..
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
