JamesJudasPries's avatar
Oct 18, 2016
Light bulb ohms. What the heck is going on here?
Hello
This is really bugging me.
I decided to measure a new incandescent light bulb I was installing at home with a multimeter, since it had no marking. I thought sure, I could figure out if this new lamp was a 40 watt lamp by calculating its amperage from the 120 volts and its resistance. But then my multimeter said 32 ohms. Not a chance I thought, that would mean the lamp draws almost 4 amps, which is way way too much. Shouldn't it measure more like 320 ohms?
Then I measured a 60w lamp which was marked as such, and the meter reported 17 ohms.... not a chance that is right... an 850 w lamp? No.
Is my meter on the fritz? I measured a silver ring, and it got .01 ohms, which seems reasonable. What the heck? Plus the range is in the 200 ohm range, the lowest range logical for things go figure, under 200 ohms... Why would the meter accurately report low readings but not high? it seems to be off by a factor of 10!
Thanks for any insight
  • Measure the resistance when hot, it varies with temperature. Be very quick ;-)
  • When you hit that filament with 120 volts its resistance "instantly" goes real high to limit the current to the wattage of the bulb.
