MrWizard
Feb 06, 2015Moderator
your safari has an electrical Bay /compartment
ours is outside on the drivers side near the rear, between the wheels and the generator
located in there is the inverter and the "transfer switch"
your TV also used as the rear view monitor, is powered by the inverter
your vacuum cleaner was too large a load, and trip the inverter overloads
there are input and output "push button" overloads aka circuit breakers on the front of the inverter, IF you have the "freedom" model from "heart interface"
also the on off switch
turn it off, reset the breakers "push in to reset" and then turn the inverter on
try using the outlet above the dining table, or around the bed
those are not on the inverter
the generator must be running or you must be plugged into shore power for the NON-inverter outlets to work
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
