Scott_M's avatar
Scott_M
Mapping and GPS Recommendations Needed
We are considering purchasing a GPS unit when we restart taking long trips. I love the old state Gazetteer map books, but I also like being able to see where the next gas station is located, as well as the next campground. Cell phones and Google maps are OK, but when you are in of those little black areas on the cell coverage maps, it may as well be a black hole. I see that there are now a bunch of GPS units marketed for RV use, but were probably designed for truckers. Garmin seems to lead the pack with the shear number of units that they make. I would like something that has an address book and shows locations of gas stations, stores, campgrounds and other amenities, as well as road hazards, weight restrictions and low bridge warnings.
I recall a PC based program about 15 years ago called Streets and Trips or something like that. You could pick your route and a corridor along that route showing any roadside amenity you had turned on. However, you couldn’t take it with you. I was hoping to find a GPS unit that had similar features that didn’t need a PC, WIFI or cell signal to work. Since we have a larger rig now, weight restrictions, road construction and low clearance bridges could be a problem. We like back roads which may have additional clearance, weight or width restrictions.
I found the RV Trip Wizard which looks a lot like the Streets and Trips program mentioned above. It will run on a tablet or phone, but I believe that it would require wifi or cellular service. Anyone use this subscription service? It seems to show many POI’s, including campgrounds, food and current fuel prices. Any thoughts or recommendations are appreciated for the travel map toolbox.
  • All the PC based navigation programs are extinct. MS Streets and trips, Delorme Street Atlas are kaput and while the software, if you have a copy, still runs they are getting more and more out of date. I have them all. Street Atlas does not seem to run very well on modern computers either. It has gotten very slow to update meaning you will be well past a turning point when the software suddenly announces you are OFF ROUTE! I'm about to buy a navigation panel myself altho I've resisted doing so for years.
    Right now your best choice for planning is RV Trip Wizard RVTW which has a phone app that does real time navigating. Otherwise you are stuck with Google maps and those Navigation panels like Garmin sells. RVTW has many features, it shows just about all RV parks, places like Walmarts or Campingworlds, it routes the trip to avoid low bridges and such and the list goes on and on.
    RVTW
