- cleo43Explorer
Welcome to the club..
Count me in.
In life we tend to look for difficult solutions, overlooking the easy ones. - 1492ModeratorThis is much more common occurrence with laptops than one might think.
- wa8yxmExplorer IIIWelcome to the club.. That is a very common problem (Stupid User Error) I would love to tell you I've never done anything like that.. Yes, I'd love to tell you that.. But alas, I can not lie. I have done that very thing.
- BobboExplorer IIII feel like such a DUNCE!!!!!!!
I bought an OEM replacement card. Took the laptop apart and replaced the card in the computer. Powered up to show DW that it is now working. NO DICE!
Now what?
I go online for ideas. I find a link that says to look in the setup to be sure all the wireless are enabled. OK. Reboot, then press F2 at the proper time to get into setup.
While it is rebooting, I look for the F2 key. Printed on the F2 key is a picture of a wireless antenna!!!!!!!!!!!!!!!!!!!
NO!!!!!!!!!!!!!!!!!!
I let it boot up normally, then press the F2 button with the picture of the antenna on it. GUESS WHAT? WIRELESS CAME ON!!!!!!!!!!!!!!!!!!!!!!!!
The problem all the time was that DW had bumped the F2 key and turned off wireless! All I had to do was hit F2 again to turn it back on!
I AM AN IDIOT! - BobboExplorer IIIOK, I ordered the same card that is already in there from AMAZON. Thanks guys.
- kjburnsExplorerI just checked and Amazon has some internal wifi cards that might fit. It seems like they have everything and anything I look for now, and generally for less than Newegg.
- KA4EBUExplorerThe factory wlan internal cards are cheap and easy to install. Check ebay.
- BobboExplorer III
kjburns wrote:
You may want to go the simple route and get a USB wifi adaptor.
This would be viable, if she had more USB ports. She has 2, and 1 is permanently hosting an identical thingy that is for the wireless mouse. That only leaves her 1 USB port, and she uses that for everything else.ChooChooMan74 wrote:
There should be a mini card inside the laptop that can be changed. Of course, you should not attempt this unless you are comfortable taking apart electronics.
I am very comfortable digging around in the computer guts. I was replacing mother boards in 1990. I have even done mother board repair with a soldering iron. Successfully. - ChooChooMan74ExplorerThere should be a mini card inside the laptop that can be changed. Of course, you should not attempt this unless you are comfortable taking apart electronics.
- bcsdguyExplorer
1775 wrote:
X3!
X4
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
