lenr
Jul 05, 2020Explorer III
We are finding campgrounds with decent WiFi including decent speed, but they are hit and miss. Some campgrounds are dropping cable TV and putting in better WiFi. We installed a Winegard Connect 2.0 4G which mounts up on the RV roof for better connections. It picks up either WiFi from the park or connects to a cellular 4G signal with data plans from AT&T, Verizon, or a pre-paid plan from Winegard that is a little more expensive. You have to program it to tell it what you want it to connect to, but the instructions are good. Regardless of the connection the Windgard re-broadcasts its own WiFi signal down into the RV. It works well, but still depends on some outside signal strength. Connected to a 4G signal, the data plan will determine your Gigs and speed. Our "unlimited" Verizon plan slows down to unusable after 15 Gigs so we almost never stream over it, but still use it for data.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
