Shipper's avatar
Shipper
No LNB voltage?
Have a Traveler Satellite with DirecTv and upon raising it it showed "no LNB voltage" and locked in the upright position. What should I look for to address this problem? Thanks for any suggestions!
  • The first thing you need to do is the Calibrate EL routine described in your owners manual. Once this is done and you are able to stow the antenna, see if the error goes away. Let us know.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Go to channel 9501-02 to check the receiver's 13 and 18 volts to the LNB.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
