Lynnmor wrote:
Bill.Satellite wrote:
If you plan to dump DTV and have DISH installed at home just be aware that DISH uses 2 different sets of 3 satellites to cover the US so which set you are assigned to at home can affect which dome you should buy. You will also need a wide open sky to catch all 3 satellites as they are spread across 20 degrees of sky.
The PL-7000 will receive all 3 western arc and 1 eastern arc, is this not a good option for folks with just eastern or western arc reception at home?
The problem with the PL-7000 is that you need to hit both the western arc 110 and 119 sats plus the 61.5 eastern arc sat to get all the programming available. The Winegard Pathway X2 is a much better choice since it can receive the full 3 sat set on either arc.
