rbrand's avatar
rbrand
Power for a Dash Cam
I have power going to the Back up monitor. How can I tap onto that to power a Dash Cam?
  • I just found a vacancy in the fuse block that was powered on with the ignition key. Got one of those "Tap a fuse" or "Add a fuse" at the auto parts store - powered it off of that. ST
  • I tapped into the power to my dash cigarette lighter socket for my dash cam and my GPS unit.
  • Locate the power wire to the monitor and tap into that.
    Probably runs up the driver's side A pillar cover.
    First, both devices must use the same input power.
    If both use raw 12 V, then it should be fairly easy.
    If either requires it's own power supply, then it gets a bit more complicated.
    Knowing the make and model of each device would make this discussion a LOT easier.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
