jokvist's avatar
jokvist
Question about Dish receiver # VIP211k
I am looking at switching from DirecTV to Dish Network in my RV. I am looking for information about their Dish receiver Model # VIP211k that they recommend to use with their DISHForMyRV service. I want to know if you have that receiver connected to a satellite feed from my Winegard dish (converted from DirecTV to Dish reception), will it allow you to watch an HD channel on the TV while simultaneously recording a different HD channel on the Hard drive running as a DVR.
When I call their customer support they said you could do this. I am concerned that is an incorrect answer and I don't want to go to the trouble and expense of the switch only to find that you can not do this function with that receiver.
My concern is that I thought this is a one tuner receiver and that they would need two tuners. Also with only one satellite feed plugged into the receiver I did not think that you could receive two different channels. I thought you would need two feeds plugged into the receiver.
Based on my discussion with Dish customer support the Dish receiver Model # VIP211k is the only one that can be used with their DISHForMyRV service. They apparently check the ID numbers on the receiver to confirm that it is a VIP211k.
So if anyone is using a VIP211k receiver with a hard drive connected can you test to see if this function works.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
