dspencer's avatar
dspencer
question on playing tv through stereo speakers
I have a 2013 Gray Wolf that has a basic Jenson am fm cd player. It has a aux. in input on the front and a head phone input. I know there should be a way to play the tv through the speakers but I'm not having any luck trying to accomplish this. Of course I am VERY electronics challenged. :h Any help would be very much appreciated.
  • THere are small FM transmitters available for under $20 that plug into the TV headphone plug, and will transmit to your FM stereo.
  • 2oldman wrote:
    dspencer wrote:
    Is there an adapted that you can use to use a regular auxiliary cable that I now have?
    Yes.
    Dumb question then, I assume that I just ask for an adapted for the auxiliary input then?? I am very electronics challenged.:S
    Yes.
  • robsouth wrote:
    If TV has a headphone out jack, run a wire with appropriate plugs from it to the aux input on Jensen. Set to Aux on the Jensen. Voila.. tv through the Jensen system speakers.
    I tried that but it didn't work. I don't think I have the right plug though for the aux input as what I have didn't fit in there right. Is there an adapted that you can use to use a regular auxiliary cable that I now have?
  • If TV has a headphone out jack, run a wire with appropriate plugs from it to the aux input on Jensen. Set to Aux on the Jensen. Voila.. tv through the Jensen system speakers.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
