KO's avatar
KO
Rand McNally RV GPS
I just bought the RV GPS from Camping World. I drive Florida to Yuma AZ solo twice a year ( 4 trips). As I have no copilot, my GPS is very important to me. I liked the 7 inch screen and campground feature.
I have used it twice in my car for test drives. In both cases the unit made me take some really round about way to get to my destination. The last one, I was at Target and had to turn on the main drag and should have gone straight down the road for 7 miles. The unit tried to get me to turn left at several stop lights. It did correct itself when I did not obey. And yes it was set for car not RV.
I also programmed it to go for Tampa to Yuma. It directed me to get off the interstate and drive some highway for about 40 miles and the to get back on the interstate.
I know GPS are noted for their capacity to take you out to lala land, but this unit is really scaring me!
Anyone else having this type issue with this unit?
  • I bought the RVND-7715. I set the height of my RV in at 12 feet (just to be sure to give extra clearance to my 9' RV). It was routing me onto a highway with a 7'10" height restriction with the height set at 12 feet. I contacted Rand McNally and got a stock response and no answer as to why or what to do about it. The GPS went back to the store the next day!
    I never plan a trip without doing it on the computer first but there are times when I would like to stray from the route while on the trip, and want a GPS that will not get me into trouble. The Rand was not the one.
  • I work directly with Rand McNally on the GPS unit and have contacted them to get some answers regarding these issues. Please PM me if you have additional details to share. Thanks.
  • First you need to plan with a real map, than use the GPS for and approximate route.
  • Rand McNally used to have an excellent mapping program for your computer called TripMaker. They stopped supporting this back in 2002 but I still like it better than any other option out there. I wish they would update and release that program as I think it would give Streets and Trips a real run for the money.
  • We have the 7710. Sometimes, it gives you the shortest route that takes you through some unusual places. It has settings that come keep you from doing that.
  • In preferences, you can set a preference for fastest route or shortest route. The only way to find out how much longer it will take to get there via the shortest route is to compare (i.e., do not use the "quick route" function as this only calculates and displays the preference you have set up. After gps calculates both routes, you can select either fastest or shortest. That does not impact the preference you have set.
    Unfortunately, the logic is flawed in the calculation of times for shortest routes. It will often route you through city streets with lots of traffic and traffic lights rather than routing you via a 65 mph bypass that is just 4 miles longer.
    A map and step by step routing is essential, and you can't do that effectively when driving.
    My preference is now faster-this keeps me on bypasses, but unfortunately almost always on interstates. Usually the evening before travel I look at the planned fastest route, note the travel time, and, if i don't like the route, I force a stopover (via) at a town a little more than half way down the road i think i want to go on instead. Recalculate route with via. Using fastest route again. Hopefully this will show total fastest time taking that scenic route through the via, but sometimes it sends me down the highway then back to the via, even though there are no low bridges or weight restrictions on the road to the via.
  • I too use MS Streets & Trips to plan and modify (much easier than GPS to track & change) my trips then upload it to my Garman GPS. Just learned from this forum how to upload MS to GPS and it was GREAT this summer.
    Dave
  • ALWAYS check your route against a paper map! GPS is great, but they ALL do some really stupid things at times!
    Their best function is to get you back to your RV, motel, or whatever! Go exploring, and you can get "home".
    mine came in very handy this past summer when I had to find a specific restaurant in one of those areas with all the winding streets, etc. In fact the wife, who usually disagrees with everything I say, do, or buy, said that we wouldn't have found it without the GPS.
    bumpy
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
