RJsfishin
Oct 04, 2019Explorer
Re: AM/FM antenna wiring
wgriswold wrote:
I am in the process of replacing my TV AM/FM antenna and want to use a Winegard Air 360. One problem is that Winegard recommends using coaxial cable to run from the antenna to the radio. The existing wire is just that, wire with audio plugs.
Will plain wire be an adequate substitute for coaxial cable for this purpose?
coax cable is used where there mite be a problem w/ noise or interference. So if it works w/o it you don't need it. But if its not difficult I'd pull new coax rather than wish I had.
Are you sure its not coax, because most audio cables are using coax for the same reason
