Bill_Satellite
Jun 19, 2016Explorer II
Re: Winegard Sensar Pro tweaking
Turning the Sensar Pro to 20 is not a good thing in almost all cases. That is a 10db gain (10 is zero additional gain and anything less than 10 will attenuate the signal (also necessary sometimes).
I recommend always starting a scan at 10 unless you see that initial signal strength numbers in the teens. Rotate for best signal and only turn the gain up if the numbers are still below 40-50. Do you scan and you should get nearly everything that's available. If you still have a channel that breaks up you can raise the gain a point or 2 to get it in solid.
